Dabar yra 2024 06 07, 15:31. Visos datos yra GMT + 2 valandos.
Forumas » Autodiagnostika » Klaida P0607
Klaida P0607 |
Parašytas: 2024 04 19, 18:04 |
Sveiki, vw tiguan 2011m.klaida P0607 https://ibb.co/d7W3NP7 auto kuriasi ,vaziuoja.mase gera.gal kas kokiu minciu.klaida neisitrina. |
Re: Klaida P0607 |
Parašytas: 2024 04 19, 18:16 |
faze45 rašo: |
Yra google atskleisiu paslapti
P0607 is the standard OBD-II trouble code for an issue with the engine control module (ECM). The code suggests that the ECM is experiencing problems, such as power failure or memory loss, and thus may not be able to do its job properly.
Ross tech
The victim: 2010 Jetta with TDI engine (CJAA). MIL on, just the one DTC in the ECM, P0607. Engine seems to run fine.
Officially... the fix is the chuck that ECM into the waste bin and put in a new one. We came up with a game plan:
Verify power/grounds at good no voltage drops
Shop is distributor for a certain tuning company, will talk to them about possible ECM replacement
Contact Jack to see if he can assist with used ECM
New ECM from dealer
Hours later, tech calls back, powers/ground are good. In talking with tuner, it seems they allowed free credits to try a flash and see what happens.. pay up if they get lucky. And they did, the ECM accepted the flash, the issue has been resolved, no more P0607 code and a little extra pep in the step of the engine to boot. A tune is WAY cheaper than a new ECM.
Dar raso, kad greiciu deze gali buti kalta..
Cia i tema apie vokieciu elektronika. Pas mane tokiu eiluciu keletas , kur kartasi kazkas neveikia |
Klaida P0607 |
Parašytas: 2024 04 19, 23:28 |
Mašina 2011, vcds 12, labai gali būti kad vcds rodo pievas.Nėra galimybės su naujesniu vcds pabandyti? Jei ir naujesnis rodys tą patį, tada žvairas "čipuotojas" arba EDC miršta(mažai tikėtina). |
Klaida P0607 |
Parašytas: 2024 04 20, 11:18 |
Naujesnio vcds nėra. Paklausus Google klaida gali rodyti ir dėl ne kontakto jungtyse, maitinimo, bloga masė. Buvo plautas variklis gal kur pripylė chemijos į jungtis. Nors ten turėtų būti viskas žandarų. |
Klaida P0607 |
Parašytas: 2024 04 20, 11:37 |
Naujausias vcds 23.11 , tavo 12.12 ta prasme nėra naujesnio? Jei senas china klonas tai galima atnaujinti iki berods 17 versijos. Ir nepakenktu pilną visos mašinos scan'ą parodyt. Su google mašinas tik mario remontuoja, ypač VAG'ui pagal OBD-II kodus.
P.S. vcds edc 30, 15 ir reference voltažus teisingus rodo? |
Klaida P0607 |
Parašytas: 2024 04 20, 11:45 |
enemy rašo: |
Naujausias vcds 23.11 , tavo 12.12 ta prasme nėra naujesnio? Jei senas china klonas tai galima atnaujinti iki berods 17 versijos. Ir nepakenktu pilną visos mašinos scan'ą parodyt. Su google mašinas tik mario remontuoja, ypač VAG'ui pagal OBD-II kodus. |
Remontuoja su tuo ka ka turi, jei kazko truksta tai yra ir labiau kvalifikuotu specu uz atitinkama mokesti.
jei vazhiuoja tai dar yra variantas vaziuot kol vaziuoja o ten ziurek auto ir kur gali atsitrenkti, tada jau atpuls ir remonto problemos. Shrotui tiks ir su klaidomis. |
Klaida P0607 |
Parašytas: 2024 04 20, 12:54 |
Vcds naujesnio nėra. Prie auto prieisiu tik po savaitės. Parašiau čia tik dėl to, gal kas yra susidūręs su panašia problema. |
Klaida P0607 |
Parašytas: 2024 04 20, 21:40 |
faze45 rašo: |
Vcds naujesnio nėra. . |
jei viduj ATMEGA galeciau atnaujinti.. |
_________________ geriau pilvas nuo alaus,nei kupra nuo darbo.
PANEVEZYS |
