Dabar yra 2024 05 16, 18:14. Visos datos yra GMT + 2 valandos.
Forumas » Lempinė technika » Lempinis garsas
Lempinis garsas |
Parašytas: 2020 09 01, 14:29 |
Windows 10: Vacuum Tube Player aprašymas:
Enjoy unique sound effects with Vacuum Tube Player! Using the tube sound effect, you can make music sound as if it were played using an A-class amplifier with a single-ended triode. Equalizer has a database with characteristics of 500 headphone models and can compensate for their frequency response. Moreover, it can imitate the sound of any of these 500 models to help you chose new headphones sitting on sofa, not listening them all in the store. New loudness compensation effect will restore the brightness of the music played at the lowest volume levels.
Other player features:
- Can play .flac (on Windows 10) .mp3 .m4a/.m4b/.mp4/.aac .wav .wma .ac3 .3gp .3g2 .amr
- Background playback and standard controls on lock screen
- Next track selection: tap track and player will open it next
- Covers and images gallery
- Low power consumption
- Playback schedule
- Supports huge playlists
On Windows 10 with Anniversary Update:
- Equalizer with 12 + 1 bands with Bark scale, 500 headphone presets and imitation profiles, loudness equalization in range from 20 to 80 Phon
- Tube sound effect with six tube models
- Noise gate effect
- Gapless playback
- Resampler
Collection with:
- Playlists automatically created from folders
- Playlist editor with custom file picker
- Quick add tracks to playlist or remove them using + and - buttons
- Cover art downloader; if there is no image in folder of current track it will be found and downloaded from network within several seconds
- Search by all tags at once: if you are looking for some rock from 70-s, just enter «Rock 197» in search box
- Playlist tiles
Converter (versions before Anniversary Update):
- Can sort files by artist and album folders
- Tube sound effect
- Gaps reduction
- Noise removal tool
- Eight bands equalizer
Questions you may have
Q: Tube sound on digital device? Is it possible?
A: It is just math, player emulates single-ended triode amplifier. Some popular players on PC had similar plugins. |
Paskutinį kartą redagavo fiedzia, 2024 01 20, 11:08. Redaguota 1 kartą |
Lempinis garsas |
Parašytas: 2024 01 20, 12:35 |
"Lempinis garsas" tai maždaug 1...2% iškraipymų vyraujant lyginėms harmonikoms - antrai, ketvirtai. Dar tolygus tų iškraipymų didėjimas didėjant signalo stiprumui.
Gražiai apie tai papaskota čia
https://positive-feedback.com/audio-discourse/the-pass-h2-harmonic-generator/
Plius parodytas paprastas ir efektyvus "hardware" sprendimas.
Visa kita - lempų kolbų formos ir dydžiai, auksiniai užrašai, įmantrių formų jungikliai, prijungimo lizdai ir rodykliniai indikatoriai, inkrustuotos medinės įpakavimo dėžutės skirta tiems, kurie noriai moka pinigus už išorinį grožį ir spindesį.
Kažkaip taip
Gero laiko |
Lempinis garsas |
Parašytas: 2024 03 15, 20:20 |
lampavykas raso:....."Lempinis garsas" tai mazdaug 1...2% iskraipimu...
Jus visiskai esate teisus, jei ziurite is technines puses. Jei ziureti is muzikos puses, tai tie vadinami "iskraipimai" jokios itakos nedaro.
Stai CD grotuvas, kurio iskraipimai mazdaug ne daugiau 0.02% , muzika groja daug prasciau, nei vinilo grotuvas.
Einame dar giliau. Kodel is CD grotuvo muzika per aukstos klases tranzistorini stprintuva groja prasciau, nei per klasikini lempini stiprintuva?
Su draugeliais mes jau labai seniai meginome aiskintis - kodel taip yra. Deja, tinkamo paaiskinimo taip ir nesuradome.
Tiesa. irgi tai buvo senokai. Su draugeliais dareme eksperimenta. Kadangi vienas is musu draugeliu gerai moka groti akustine gitara, tai nutareme paziureti per oscilografa - kaip atrodo muzikinis sinusas.
Mikrofono deka per oscilografa galejome visa tai matyti.
Ka pamateme per oscilografa - mus labai nustebino. Vadinamas sinusas nelabai buvo panasus i tikra sinusa. Labiau tas matytas sinusas atrode panasus i sumaigyta sinusa, kurio vadinami iskraipimai mazdaug 5...10%.
Deja klausoma muzika skambejo labai maloniai. Jokiu priekaistu mes neturejome.
Todel reziume butu tokia.
Negalima lyginti muzikos garsa is technines puses, nes tai yra visiska nesamone |
Lempinis garsas |
Parašytas: 2024 03 15, 22:23 |
"Tiesa. irgi tai buvo senokai. Su draugeliais dareme eksperimenta. Kadangi vienas is musu draugeliu gerai moka groti akustine gitara, tai nutareme paziureti per oscilografa - kaip atrodo muzikinis sinusas.
Ka pamateme per oscilografa - mus labai nustebino. Vadinamas sinusas nelabai buvo panasus i tikra sinusa. Labiau tas matytas sinusas atrode panasus i sumaigyta sinusa, kurio vadinami iskraipimai mazdaug 5...10%."
Pasidalinkit patirtimi - po kokio gėrimo vartojimo (portveinas, vermutas, brendis etc...) ateina mintis kad gitaros stygos generuoja sinusą? |
Lempinis garsas |
Parašytas: 2024 03 16, 15:00 |
Contax raso:....ateina mintis, kad gitaros stygos generuoja sinusa?
Toli eiti nereikia. Manau, kad daugelis dar pamena toki atveji, kai vienas zmogelis eidamas salia upes - paemes nuo zemes akmeni mete i upe.
Tas zmogelis pastebejo, kad vandens "sugeneruotos" bangos buvo labai panasios i sinusa.
Nuo to laiko mokslininkai pradejo naudoti sinuso pavadinima. Visus ore sklindancius signalus pradejo vadinti sinuso bangomis.
Jei paimsime pirstais viena gitaros styga ir ja paleisime - tai pamatysime, kad ta styga virpa kaip tikras sinusas.
O jeigu gitara sugrosime muzikini kurini - tai tikro sinuso jau nepamatysime.
Apie tai jau rasiau |
Lempinis garsas |
Parašytas: 2024 03 17, 12:57 |
Buvau užtikęs aiškinant, kad tranzistoriai turi atbulines sroves - nuolatinė mikrosrovė iš išėjimo prasimuša į įęjimą, o lenpa yra vienkryptė. Bet praktiškai pigūs lempinukai negali apgroti kelis kartus brangesnio tranzistorinio.
Mano asmeniniais pojūčiais gero lempinuko garsas patinka jame esančiu aidu/reverberacija. O tai ir padaroma skaitmeniniu būdu. |
Lempinis garsas |
Parašytas: 2024 03 17, 14:59 |
fiedzia rašo: |
Materialus pasaulis nėra idealus, kad ir kaip kas nors to norėtų
Lempos irgi turi atbulines sroves. Dar baisiau - ten kolbos viduje elektronų debesys vietomis susidaro. Kartais net ima žaibuoti
Senesnės lempos dar ir rentgeno spindulių sugeba pageneruot į išorę
Dėl "apgrojimų" tai čia jau kiekvieno asmeninė patirtis
Pvz teko garsiai paklausyti galingą lempinį aparatą - kėlė nuo grindų kAlanėles ne blogiau už tranzistorinį
Tačiau tyliam naktiniam klausyme tas galiūnas "gavo į kaulus" nuo PCL82 SE aparačiuko. Tiesa, svoris abiejų lempinių buvo panašus, nes tie SE transformatoriukai tokie didoki pasitaikė |
Lempinis garsas |
Parašytas: 2024 03 29, 15:04 |
lampavykas rašo: |
Tačiau tyliam naktiniam klausyme tas galiūnas "gavo į kaulus" nuo PCL82 SE aparačiuko |
Keista, nes naktinis rėžimas, mano žiniomis, priklauso tik nuo kolonėlių. Geroms kolonėlėms net dažniai nėra derinami.
PS
Turėjau daug tūkstančių kainuojančias Tannoy kolonėles. Atsitiktinai gavau po 20 eurų su 4A-28Y4. Kai pastebėjau, kad Tannoy jų neapgroja, iš karto pardaviau. Lyginau kolonėles skirtinguose kambariuose, vienų su kitom tame pačiame kambaryje nelyginau. Tai viduriniai skamba labai panašiai. Dabar jas galiu klausyti ties girdimumo riba. Bet papildžiau supertweetr'iu su 3gd-2 ir dar subą turiu, kurį gailą pusvelčiui parduoti, nes už naują mokėjau. |
Lempinis garsas |
Parašytas: 2024 03 30, 11:00 |
fiedzia raso:....mano ziniomis, priklauso nuo koloneliu.
Zinoma. Prisimenu tuos laikus, kai gamintojai pradejo naudoti kolonelese garsiakalbius su gumine pakaba. Muzikos garso kokybe stipriai krito zemyn.
Kodel garsiakalbiu gamintojai tokiu dalyku tada nesuprato - sunku tai paaiskinti
Toli eiti nereikia.
Prisiminkime, kai buvo sukurtas CD formatas. Daugelis tada mane, kad tai bus didelis suolis muzikos garso pagerejimui. Kai klausytojai isgirdo kaip groja muzikinius kurinius CD formato irasai - daugelis suprato, kad tai apgaule.
Einame dar gyliau.
"TESLA" automobiliai. Kodel "TESLA" automobiliu autorius mane, kad tai bus didelis progresas automobiliu pramoneje?
Deja, kazkodel eiliniai vartotojai labai greitai ivertino tokius automobilius neigiamai.
Reiskia, kad eiliniai vartotojai geriau nusimano apie automobilius, nei pats tokiu automobiliu autorius.
Ar megins "TESLA" automobilio autorius padaryti rimtas isvadas - laikas parodys. |
